933 cat clutch question?
winston
05-21-2002 18:57:21
Overall I am happy with the new to me machine, trying to decide what I need to fix now and what can wait. With the trans in gear and clutch disengaged the machine creeps, after running the machine for a bit it stops doing it. This makes shifting difficult, this is the model with fwd/rev shuttle. Is this normal or a sign of problems, I am going to change fluinds soon.
Bob /Ont.
05-21-2002 19:17:47
 Re: 933 cat clutch question? in reply to winston, 05-21-2002 18:57:21
Winston, I think you should look at the clutch brake. It should stop the clutch when you push forward on the clutch lever in the disengaged position to shift gears.
later Bob
winston
05-22-2002 06:06:03
 Re: Re: 933 cat clutch question? in reply to Bob /Ont., 05-21-2002 19:17:47
sorry, I forgot to mention that I adjusted the clutch/and brake, before doing this I had to start it up in gear. With clutch disengaged the machine moves to shift i got to stop the machine, idle engine down, put on the clutch brake, then shift. after running for a bit every thing works the way it should don't even need to use clutch brake, changing fwd to rev. It has a wet clutch I was thinking it might have somthing to do with the oil causing drag in the plates.
Bob /Ont.
05-22-2002 07:42:49
 Re: Re: Re: 933 cat clutch question? in reply to winston, 05-22-2002 06:06:03
That said Winston, I think you are on the right track, plus some steady work and it'll be fine.
Later Bob
Ralph Hoeverman
05-25-2002 15:08:03
 Re: Re: Re: Re: 933 cat clutch question? in reply to Bob /Ont., 05-22-2002 07:42:49
Hi where did you get new machine? I also got 933g and still cleaning it up. There was one for sale on e-bay in pa it had 4-way bucket do you know how to plumb one up? Any imfo would be greate Thanks Ralph 1-908-456-0121
winston
05-27-2002 14:45:19
 Re: Re: Re: Re: Re: 933 cat clutch question? in reply to Ralph Hoeverman , 05-25-2002 15:08:03
Ralph, this machine wash purchased in Halifax, Nova Scotia. Bought it from the orignal owner, it sat in a feild for several years the old guy would put batteries in it and start er up now and then. This machine has the quarry bucket on it the multipurpouse bucket would be a nice add on. I got the operators, and parts manual with the machine it shows the hook up for the multipurpose bucket. would that be any help to you? winston
Ralph Hoeverman
05-27-2002 18:52:33
 Re: Re: Re: Re: Re: Re: 933 cat clutch question? in reply to winston, 05-27-2002 14:45:19
Yes It would be my manuals dont show how one would be added to this 933gmodel? How old is your 933? I found one on e-bay that had a 4-way bucket in pa. I called him he could explain how it was hooked up. That weedend he sold it, and it went to virgina really would have like to get a copy of plumbing mounting imfo. Thanks Ralph 1-908-456-0121
winston
05-29-2002 18:50:09
 Re: Re: Re: Re: Re: Re: Re: 933 cat clutch question? in reply to Ralph Hoeverman, 05-27-2002 18:52:33
this one is a 1969 model. I will try... to scan some pages for you tommorow. Is your email good? I sent you a message did you get it?
Ralph Hoeverman
06-02-2002 09:21:38
 Re: Re: Re: Re: Re: Re: Re: Re: 933 cat clutch question? in reply to winston, 05-29-2002 18:50:09
HI I got your e-mail late our server is have is really bad and we are looking for a changeour server but they are not worth very much. get back to me 1-908-456-0121 Ralph
Bob /Ont.
05-26-2002 18:03:07
Ralph I assume you mean a clamp bucket. Sides and bottom swing up and can pinch logs and things. The best way is to add another spool that way the circuit is protected by line(port) relief valves. It can be done on the cheap with a rotary valve to divert the tilt flow but I wouldn't advise it.
Later Bob
