Hd
Keith in Mt
05-23-2002 06:45:12
I was wondering what is the diffents between a hda and hdb it likes like hd g is a loader thanks Keith
ACPhil
05-23-2002 09:22:42
 Re: Hd in reply to Keith in Mt, 05-23-2002 06:45:12
What model Allis Chalmers tractors do you need info on? HD 5, HD 6 , HD 9, HD 11? Let me know, and I'll try to help you out. Phil
Keith in Mt
05-24-2002 05:33:27
 Re: Re: Hd in reply to ACPhil, 05-23-2002 09:22:42
A hd 6 I have A hd6b aand Iam hope hdd6a parts will inteerchange
ACPhil
05-25-2002 04:52:07
 Re: Re: Re: Hd in reply to Keith in Mt , 05-24-2002 05:33:27
Good Mornin'. Here goes. HD6A's up to S/N 5100 had 44' track guage and 33 link tracks. HD 6A's S/N 5101 and up had 44" track guage with 34 link tracks. In the early 1960's HD 6A's were dropped from AC product line. The 6A model were tractors made for agricultural work, hence the narrow width. Many had turbos on the engine to boost horsepower in higher altitudes. The HD 6B's had a track guage of 60". I looked in a few books I have, and didn't get any clear explanation on how AC made the machine so narrow. Maybe the final drive case and sprocket shafts are shorter. I'd measure both machines across the final drive case, from sprocket to sprocket. IN 1963 Allis Chalmers used the 6000 series diesel engine in the HD 6. The early engine had 344 c.i. and so did the 6000 series. The 6000 series had a different cylinder head and different pistons. This was done to help promote easier cold starting and better power. The early 344 engines had the injectors on the left side of the engine just above the injector pump, and they were mounted horizontally. The 6000 series engine has the injectors mounted in the top of the head, behind the muffler. The engines will bolt in either machine. Let me know exactly what you want to interchange and I'll go my best to help. E-mail me if you want. HAPPY DOZIN' Phil
