Ford vs. Case Backhoe
Pete H
05-28-2002 11:00:20
I知 looking to get a used backhoe. I知 a bit torn between what brand to get. My budget is in the $9K to $10K range. Searching locally there are lots of 580Bs and a few 580Cs. But there are also a few Ford 555 models that are a lot newer in my range. Does anyone have experience with both backhoes and has a preference? Is either one built better than the other? Are 580 parts easier to find than the Ford parts?
Thanks for any info!
Pete H
Waupaca Wisconsin
sclan
03-16-2004 18:06:15
 Re: Ford vs. Case Backhoe in reply to Pete H, 05-28-2002 11:00:20
I have a Ford 655C and have 7800 hours on the unit. It is a very strong and fast hoe and if you spend the money on proper maint, it might be the best bet in the long run if you want to keep it long term. Short term, Case / Cat for resale. As for JCB you might want to check out your local scrap yard.
How about a CAT?....Mr. J
05-28-2002 21:22:00
You should at least consider a 2 stick CAT backhoe. If your new, the 2 stick system is much easier to master than the 3 sticks of the Case and Ford...
My 2 cents..
Mr. J
A CAT in my price range?.....Pete H
05-28-2002 23:38:31
 Re: Re: Ford vs. Case Backhoe in reply to How about a CAT?....Mr. J, 05-28-2002 21:22:00
I've seen a few CATs in the farmers paper and none of them were any where near my price range. Are there older Cat TLBs below $10K? I'd love to get a CAT but even on machinerytrader.com the cheapest Cat (416) was $13K.
bob
05-28-2002 20:01:00
i am a retired operating engineer,and as far as i am concerned there is no comparison.case is the best small hoe made,and for sure the toughest.they just wont quit.
Joseph
05-29-2002 17:57:06
 Re: Re: Ford vs. Case Backhoe in reply to bob, 05-28-2002 20:01:00
I have been an equipment operator for 10 years and i have to agree with Bod that ford and case have no comparison. If you want junk then but the ford if you want a real machine then go with the case even better a John Deere that is a couple of years old. I have run Ford,Cat,Case,John Deere,JCB and if i had to choose one it would be a Case or a Deere.
gatractorman
05-28-2002 17:26:37
Both are good hoes but if it were my money I would opt for the Case it might not be as strong or fast as the Ford but longevity counts alot for me.
Bob /Ont.
05-28-2002 13:05:33
Pete, I have never owned or ran either one of them but I see as many case's around as anything, they must be okay. Later Bob
ben
05-28-2002 11:12:07
you should be able to get a sweet machine for that kind of money if you are patient. i have had a ford and a case 480c riht now. even though the case is older i can still get just about any part i need, my dealer almost always stocks it. they are easy to work on. they even had the plastic knob for the shifter!! if you get a case do not get anything older then a C because you have to split the tractor to do a clutch. the C and newer you can ust pull the tranny, engine etc. i am told the D and newer are the best cause you get an even better engine , its a cummins.
jimc
05-30-2002 15:23:55
 Re: Re: Ford vs. Case Backhoe in reply to ben, 05-28-2002 11:12:07
Get a Real Backhoe/ loader not one of these American Toys.Buy JCB the only Real Man`s equipment.
