ED-208 engine
Levi
02-12-2001 14:29:45
I am trying to start a Terratrac loader with an ED-208 continental diesel. It has a Roosa Master pump. The injection pump jumps or moves while I am turning the engine over to bleed the injection lines out. When I pull the pump, the pump drive shaft slides out of the pump, it is mounted in a separate flange, and has only one bearing surface that I see. Should there be a bearing in the block that the end of the drive shaft rides in? If there should be, it's gone, there is not one there now. Any help is welcomed.
May GOD bless,
Levi
Dan
02-12-2001 22:37:23
 Re: ED-208 engine in reply to Levi, 02-12-2001 14:29:45
I have a parts engine if need anything
