350B final question
Steve
06-02-2002 17:07:24
Does anyone know what might cause one of my finals to quit working? I rebuilt the left side steering clutch and brake last year. Now the right side will not power. I noticed that when I applied the right lever, I would choke the motor.
I figured I was out of adjustment, and just applying the brakes to that side, causing the motor to strain. Anyway, this past weekend I used the machine alot. I was on a hill and threw the track and being on such an angle ran her out of fuel. Got the track on and running O.K. But the right drive will not work. It was acting up befor the track and fuel problem. Once on level ground I can drive the machine, but cannot turn left. I guess the right side is just rolling, but without power. Any Ideas???
gatractorman
06-03-2002 02:36:13
 Re: 350B final question in reply to Steve, 06-02-2002 17:07:24
Hey Steve sounds like something is up in the right side steering clutches, sounds like an adjustment problem before the track throwing deal, but now if it wont power at all you probably have stripped the fiber teeth off the clutches. Does it still try to choke the engine when turning right?
Steve
06-03-2002 05:17:51
 Re: Re: 350B final question in reply to gatractorman, 06-03-2002 02:36:13
No It doesnt try to choke the motor now. Could the clutch be so out of adjustment that it stays on?
gatractorman
06-04-2002 01:44:50
 Re: Re: Re: 350B final question in reply to Steve, 06-03-2002 05:17:51
I guess that could be possible but I wouldn't think probable, check the free travel in the lever to be sure the T.O. bearing is coming away from pressure plate or take the inspection cover off and with a flashlight look down in there and see that the T.O. bearing is not riding on pressure plate fingers until you move the lever.
