JD 2010 crawler
Paul
06-02-2002 21:08:14
The right steering clutch has turned right for the last time. I need scanned pictures and procedures for this job, on removing the steering clutch. Why couldn't JD copied cat or int. or allis on steering clutch removal. I will also be looking for parts later.
John bergman
06-06-2002 15:32:11
 Re: JD 2010 crawler in reply to Paul, 06-02-2002 21:08:14
Make sure you take off the side that is causing the problem. If the dozer does not turn to the right, either the right brake is not working OR the left clutch is slipping. I have had a few freinds that have taken apart the wrong side just to find no problems...Most manuals and parts are still available at John Deere dealers. Sometimes you can just clean off the clutch discs and they will work fine.I suggest that you check the adjustments also, ofcourse you probably already have..If I can help with information just e-mail
