Case Skid steer hot exhaust
Sonny
06-03-2002 09:53:59
Just purchased an 1835 Case skid steer with the Case gas engine. Exhaust manifold gets red hot after running a short time. Coolant is ok & circulating. Any suggestions?
Chris Brown
06-04-2002 06:02:20
 Re: Case Skid steer hot exhaust in reply to Sonny, 06-03-2002 09:53:59
a gas engine running at a fairly high rpm working under load should glow the exhaust manifold red.gas manifolds run alot hotter than diesels.
Max
06-03-2002 20:44:31
Those engines should have a manifold temp of around 950-1350 degrees F. Sounds like a timing or fuel problem.
