D4 cattapillar
mark
06-08-2002 20:10:03
have 1946 d 4 dozer and the blade dont lift up and down it did it just quit it has pump on front and its still spinning need help trying to build pond
terry mitchell
10-30-2002 10:59:36
 Re: d4 cattapillar in reply to mark, 06-08-2002 20:10:03
Did you check if pump has pressure IF IT does Check and see if valve is bypassing
Terry 30, D6, D8
06-14-2002 12:22:57
Mark,
I had hyd problems on my D6 as well. Some suggestions:
1. look in your hydraulic tank while engine is running and see if the oil is flowing. If not, you have a pump or drive problem.
2. is the blade twisting as if one cylinder wants to lift and the other does not. You need new seals on the cylinder. 3. try inserting a pressure gage upline of the pump. if you have good pressure at the pump while actuating the valve, your control valves may be leaking.
I had to fix all of these problems. Drive, then pump, then cylinder, then valves. Mine was in pretty bad shape, but works great now. Good luck.
Bob /Ont.
06-09-2002 07:25:39
Did this happen all of a sudden of gradually get worse Mark?
Later Bob
