Fuel pump TD-9
chuck
06-12-2002 18:29:49
could someone tell me if you are suppose to put oil in these pumps and if so how much. or do u put diesel fuel in the pump filler....thanks
Rick from Paso
06-17-2002 22:40:53
 Re: fuel pump TD-9 in reply to chuck, 06-12-2002 18:29:49
There should be oil in the pump, if there is diesel fuel like mine, your scavange valve is not working properly.
wheatland47
06-12-2002 20:43:31
I belive you add the same oil as you put in the crankcase, and there should be a level plug on the side of the pump to let you know when it's full. It doesn't take much, less than a pint I think. Check it every day, just as you do the crankcase level.
