JD 350 DRIVELINE ENGAGEMENT PROBLEM (need help)
Ed
06-30-2002 05:37:02
The JD 350 I just purchased has to run for about 15 min or so when I first start after it has sat awhile before the power to the driveline is activated. Power to the blade is never affected, just to the drive. Is this a reverser problem? Wrong fluid in reverser? Any suggestion would be appreciated!
Thanks
Ed
gatractorman
06-30-2002 14:26:54
 Re: JD 350 DRIVELINE ENGAGEMENT PROBLEM (need help) in reply to Ed , 06-30-2002 05:37:02
sounds like its got a leak in the suction line and the pump is losing its prime after it sits a while, I used to have a 350 that done me the same way but only in wintertime and because I was running thicker oil in it, but this time of year this is probably not your problem, try overfilling the tranny a bit see if that helps.
Ed
06-30-2002 17:37:01
 Re: Re: JD 350 DRIVELINE ENGAGEMENT PROBLEM (need help) in reply to gatractorman, 06-30-2002 14:26:54
Thanks Tractor Man
Will try the overfill and let you know what happens!
