Fiat-Allis 14 C Bulldozer
Simon
06-30-2002 14:41:51
Steering system will not work. Tried to loosen the fluid lines to the valves and tried to turn steering but no squirting fluid although fluid level is ok. Also, where can I get a copy of the repair manual for this dozer? Can some out there help?
Billy Cathey
07-02-2002 21:13:28
 Re: Fiat-Allis 14 C Bulldozer in reply to Simon, 06-30-2002 14:41:51
Don't know where you live! But I ordered manuals for my FL14B from a Fiat Parts Dealer in Dallas, Texas. The Fiat Dealer is Bane Machinary Inc. on Manana Dr. Dallas, Texas Ph. 214-352-2468. Hopes this helps. As for the steering, could be a number of things, if no fluid then yes check pump and filters. Also depending on the age of your machine, probably also the seals,rings, hubs and pistons at the steering drums. Good luck and hope this helps.
gatractorman
06-30-2002 15:02:30
sounds like a steering pump problem, should have psi at the valve anytime machine is running, did it do it all the sudden or gradual or has the machine been sitting? Sorry no help on the manual
