JD 2030 will not start
Simon
06-30-2002 16:16:16
My JD 2030 recently ran out of fuel and went dead. I replenished fuel but it will not fire up. I then tried to spray ether into the air breather, but will not fire up either. Can someone help?
gatractorman
07-02-2002 03:08:14
 Re: JD 2030 will not start in reply to Simon, 06-30-2002 16:16:16
Your gonna hafta re-prime the fuel system, first make sure your filter is full then loosen all injector lines at injectors be sure to use a back-up wrench on the line outta the injector you will see what I mean when you go to loosen them, then spin engine till fuel comes out where you loosened lines, tighten and it should start up.
