INT. T-340
Al
07-31-2002 04:45:44
I have a 1963 international T-340.
The engine runs rough and will stall unless I run it with the choke partially open, then it runs smooth.
any ideas on the cause, and fix.
also what type and number spark plug would this engine take?
thanks for any and all help.
Polish Mike
07-31-2002 12:45:24
 Re: INT. T-340 in reply to Al, 07-31-2002 04:45:44
Sounds like it's time to clean/rebuild your carbureator. I'm betting that you let it sit for a fairly long period of time between uses. The gas gets gummed up in the carb jet and results in a real lean mixture, which is why it'll run better with the choke on. Clean the carb, and start using a stabilizing additive to the gasoline ( like "Stabil" ). Hope this helps ya.
Ralph Hoeverman
07-31-2002 20:17:46
 Re: Re: INT. T-340 in reply to Polish Mike, 07-31-2002 12:45:24
Hi Guys got a t-340 my self Its been sitting for years. As soon as i heal up from surgery I want to bring it home. I was just out in Pa at wengers they have a couple of them for parts.If you need anything If you have any ? or suggestions about t-340 weak or strong points let me know I have Ithink all the manuals for it, but dont have the dos or donts with this machine let me know what you think and if you need a copy of manuals let me know and i can get one copy up Thanks Ralph
ron
07-13-2003 15:05:16
 Re: Re: Re: INT. T-340 in reply to Ralph Hoeverman , 07-31-2002 20:17:46
I am looking for books on my t340 too if you can spair them.
David harkness
05-12-2003 10:04:35
i am looking at a t 340, can you email me and give me some information on this machine. gas powered, 6 way blade. ARE PARTS AVAILABLE? interested in manual if i purchase the dozer. thanks dave
Wes
10-09-2002 21:24:40
I have a T-340 sitting in the shed that I'd like to get back in shape. I'd be very interested in a copy of your manual if that is possible.
I don't know if my machine is worth fixing or not but I'm going to find out what I can about them. It does run but just barely right now. It seems to have a high time engine that likely needs rebuilding but I don't want to go to the trouble if there are other serious problems. I'm told the finals need attention and that the track pins are worn badly too.
Best, wes
