1970 Case 450D Dozer Track Master Pin
Ric
08-08-2002 02:49:18
How do I tell which pin on the track is the master pin? I need to break the tracks to put reseal kit in adjusters.
marlowe
08-08-2002 19:44:53
 Re: 1970 Case 450D Dozer Track Master Pin in reply to Ric, 08-08-2002 02:49:18
if you are going to reseal the adjuster you might just want to replace the adjuster because they ware and rust out in side and a new seal will not work check for ware and rust pits it don't take much for it to leak and to replace is a pain. a new adjuster is about 250 after market then the job is done in one try. good luck
Dave N
08-08-2002 04:09:31
The pin should have a hole counter sunk in the end of the pin about 1/8 deep
Max
08-08-2002 18:40:28
 Re: Re: 1970 Case 450D Dozer Track Master Pin in reply to Dave N, 08-08-2002 04:09:31
You may have to go underneath between the tracks to find it for the pin used to be marked on just one side, the smaller side. The master pin is installed inside-out but some people like to install them the other way.
Ric
08-08-2002 17:14:22
Thanks Dave.
