D3B Starter Fix
Tom H
08-08-2002 15:50:30
Somehow the top mounting bolt of the starter on my D3B crawler snapped off. The starter is now just hanging by the other 2 bolts. I can see the one closest to the engine panel and have NO idea where the other one is located. So far I have taken all the wires off and am now puzzled how do you get at the other 2 bolts???? Even the one I can see I can't see how I can get a ratchet and extension squeezed in there. Any/all help is appreciated.
Thanks, Tom
John Craughan
08-08-2002 17:21:03
 Re: D3B Starter Fix in reply to Tom H, 08-08-2002 15:50:30
You have to pull the belly pans to get access to the bottom starter mounting bolt. Run the machine up on a couple of timbers and lock the brakes. This will give you a little more shoulder room for rermoving the pans. I always use a come along to hold the pan in place when taking out the bolts and then gently lowering it to the ground.
Good Luck
