Damage to elec system
Polk Crawler
08-13-2002 06:27:29
if battery cables get switched to wrong battery terminals in a postive ground system on a tractor, what damage results and how serious is it for repair etc. Thanks PC
Bob /Ont.
08-13-2002 13:33:27
 Re: damage to elec system in reply to Polk Crawler, 08-13-2002 06:27:29
You said POS ground, therefore I assume you have a generator and this is an old tractor. The dammage is likely light. Hook it up right and if it charges and the cutout relay isn't welded shut you are okay.
Later Bob
Kelly
08-13-2002 11:52:21
P.C.,
One should make certain that the correct polarity will be maintained. If the polarity is reversed by accidentally reversing of the terminals,the diodes in the alternator,transistors in the radio, transistors---when used in the ignition system and etc. Will, or could be ruined when the engine is started and the radio is turned on.
