420c whatchamacallit
Jack
08-18-2002 19:30:08
on the 420 right in front of the gas tank there is a porcelain or ceramic block with two connectors on on each end.
What is the official name ? Any one have a part number so I can replace it?
Do you know if it is cracked or wobbly if it will prevent the start of the engine?
I know cars use to have these to on the firewall.
thanks for any and all help.
jack
Lavoy
08-22-2002 20:41:43
 Re: 420c whatchamacallit in reply to Jack, 08-18-2002 19:30:08
Has your crawler been converted to 12 volt? IF it is still 6 volts it should not have one. Otherwise, go to a parts store and buy a Chrysler ballast resistor. I think the Wells Ampco number used to be CR106.
Lavoy
Jim in Michigan
08-21-2002 14:19:08
I have a 430 C and I am looking for pictures of the handle that makes the blade go up or down,, mine was disassembled and I cant quite figure it out., it has 2 rods comiung from the valve going to the handle.. One goes to one handle the other goes to some weird setup,,anyone have pics of this ? HELP.!!!!!...Jim
Curt
08-19-2002 20:23:39
ballast resistors, mopars used them if they are cracked, they wont run
