Cat crawler?
Matthew
08-21-2002 19:43:46
While leveling off an old strip mine site here in WV i hit something solid.Well went and got the hoe and two hours later i was the owner of part of an old crawler.Would like to know what it is.Has a brass tag on the rear left main case.It says: Tractor Number 5J2821SP Has a swinging drawbar.The casting numbers look like Cat numbers. Any ideas?
Kelly
08-21-2002 23:25:04
 Re: Cat crawler? in reply to Matthew, 08-21-2002 19:43:46
Matthew,
Sounds like you have uncovered a Caterpillar D2, the D2 5J series was built from 1938 thru 1947 your S/N 2821SP would be a 1940. Earlier models equipped with special transmission groups were designated by the letters "SP" on the tractor serial number plates. Such a marking on models of the mid 1950's indicates special final drive gear ratios.
Bob /Ont.
08-21-2002 20:13:19
Sounds like you gave us a ser # sp would be special purpus I think. Look it up tomorrow and get back.
Later Bob
