450c oil presure
Roger Greenfiel
09-03-2002 21:23:02
I have a JD 450c crawler and I would like to know how much old presure it should have at 1500 rpm. Mine has about 30lbs. When I it put under laod it drops down to about 5lbs or lower. It don't use oil and runs good. What kind of trouble am I in and what should I look for. Thanks
Jonathan
09-04-2002 21:25:23
 Re: 450c oil presure in reply to Roger Greenfield, 09-03-2002 21:23:02
When you say it drops when under a load, does that mean when the rpm's drop ?? ...As a rule , Jd engines of that size don't normally have bearing problems that result in drastic oil pressure loss...what could be a source of leakage is the balancer shafts and/or bushings...they are in the pressure lube circuit and are usually overlooked at in-frame overhauls. The bad news is that they are not replaceable without more disassembly than is usually required in an in-frame overhaul.Also make sure it has the updated oil pressure regulator and spring..
the tractor vet
09-04-2002 17:26:42
I am thinking that hot it should have around 45 psi. and if it is dropping that bad the i would think that it is time for mains and rod bearings and a new oil pump. Just what weight oil are you running in it , first try some stright seires 3 thirty weight or even forty weight.
ROGER
09-04-2002 19:15:14
 Re: Re: 450c oil presure in reply to the tractor vet, 09-04-2002 17:26:42
tractor vet I got 15-40 in it. I think you might be right it is time for mains and rod bearings before I end up with more troubles. thanks
G
09-05-2002 18:31:51
 Re: Re: Re: 450c oil presure in reply to ROGER, 09-04-2002 19:15:14
If you are going to the trouble of rods and mains, do the balance shafts too. At least check them real close if you do not want to pull engine. Good luck.
