Anyone know where I can find a TD-9 Clutch coupling, and or a clutch release fork
Morgan
09-04-2002 23:22:58
Anyone know where I can find a clutch coupling with good teeth and also a clutch release fork for my TD-9? Discovered while taking the clutch out that the teeth were worn down on coupling. Thanks, Morgan
hector gemme
02-09-2005 05:53:49
 Re: Anyone know where I can find a TD-9 Clutch cou in reply to Morgan, 09-04-2002 23:22:58
HI I HAVE SOME TD9 PARTS
wheatland47
09-08-2002 16:49:06
 Re: Anyone know where I can find a TD-9 Clutch coupling, and or a clutch release fork in reply to Morgan, 09-04-2002 23:22:58
Do you mean the coupling on the clutch disc??
Hand or foot clutch?????
Morgan
09-16-2002 14:54:07
 Re: Re: Anyone know where I can find a TD-9 Clutch coupling, and or a clutch release fork in reply to wheatland47, 09-08-2002 16:49:06
I'm not quite sure what you mean by "on the disk", it clearly connects the disk to the coupling by clutch shaft. It is a hand operated clutch. there is a brake facing (as described in the manual) on that coupling, that I believe connects to the throught bearing carrier.
