JD 40C -- Stuck steering clutch lever
Bryan
09-11-2002 06:30:22
I just got a 40C that's been sitting for about 7 yrs. The left lever moves freely, but I can't get the right one to budge. How should I go about unsticking it without tearing something up? Thanks, Bryan
ro
09-11-2002 07:50:07
 Re: JD 40C -- Stuck steering clutch lever in reply to Bryan, 09-11-2002 06:30:22
When I've encountered a shaft "rust-frozen" inside a casting, I've done the following:
Drilled into the outer casting far enough to reach the 'stuck' shaft; then tap the hole and install a 1/4 inch grease zerk. I then put Kroil(penetrant) into a grease gun and use the grease gun to pressure feed the Kroil into the frozen area. Wait a while and maybe reapply, lighting tapping with a hammer in the area, to encourage dispersion of the Kroil. This also worked on loosening some detent balls/springs on an AC HD-5G transmission, that had been sitting outside for at least 10 years.
Bryan
09-11-2002 09:12:55
 Re: Re: JD 40C -- Stuck steering clutch lever in reply to ro, 09-11-2002 07:50:07
Ro, I wasn't very clear. The lever will move slightly, but it seems like the stuck part is actually the clutch itself. I don't have the little crawler running yet, but I wanted to try to break the clutch loose so I can try to pull start it. Thanks, Bryan
Bryan
09-12-2002 06:14:43
 Re: Re: Re: Re: JD 40C -- Stuck steering clutch lever in reply to CRAWLER HEAVEN, 09-11-2002 14:41:17
Is there a way to get a diagram of the final drive via email? I have a shop manual for my model 40 wheel tractor, but it doesn't cover the crawlers. Maybe the finals are the same???
David
09-12-2002 18:44:55
 Re: Re: Re: Re: Re: JD 40C -- Stuck steering clutch lever in reply to Bryan, 09-12-2002 06:14:43
Yeah just take it apart. It's not that bad a job. Especially if you could get a diagram or service manual like you say. It's possible that you will do more damage or cause unnecessary wear if everything is not cleaned up good.
possum
09-14-2002 10:48:27
 Re: Re: Re: Re: Re: Re: JD 40C -- Stuck steering clutch lever in reply to David, 09-12-2002 18:44:55
Open the top (four bolts) and front (bung) covers and watch what moves while you wiggle the handle. Chances are the stuck part is the throwout bearing, which rotates against a detent. You can reach it with oil and patience, but opening up the final is yyour best bet. Look in the left side to see how it moves.
