Cat d6 9u
brian
09-11-2002 15:54:34
any info i could get concerning changing from a dry clutch to a wet clutch would be much appreciated. the dry failed while hard into a tree, blew some of the housing off but i got lucky and found this wet clutch for sale in a local newspaper!
Darren
08-09-2003 01:23:19
 Re: cat d6 9u in reply to brian, 09-11-2002 15:54:34
Brian, One thing you will need to do is change the gear box input shaft, also the bell housing, as the wet clutch bell housing is a slightly different shape, I think this is to accomodate the oil pump assembly. The dry clutch model is mated up to a round flange on the gear box input shaft. On the wet clutch model the gear box input shaft has a rectangular flange which has a depression in the middle. This is due to a slightly different universal system.
