Hello there,New to this forum and new to this kind of equipment. I am looking at buying a 1962 International TD6 bulldozer. I have several questions because I know NOTHING about this kind of equipment, although I do know something about engines. This is apparently (so the seller tells me) the first year the TD6 was all electric start (no gas motor to start the diesel). I have started this rig and it starts right up, sounds great and doesn't smoke and has good oil pressure. I forgot to look how many hours are on it. I got to drive it and everything seemed to work. Here are my questions: 1) The turn levers (I don't know what they are called other than that) are uneven when in resting position. When you pull on the one the way you want to go, it barely turns in the direction desired unless one also applies that side's foot brake. Is this sign of some sort of wear or is it normal? 2) Can one get a winch for it? 3) Can one get a loader for it? 4) Is it considered a fairly good rig? 5) Is $5,500 too much for it?
