Are T6 oil filters the same as the TD6?
Askel
09-19-2002 15:07:26
Went to the local Tractor Supply store looking for the oil filter cartridges for my T6 crawler. It was the only IH tractor not listed. So he did some calling around and was told that the T6 was the same as the TD6 which is listed. Had one in stock and the other he has to order, so I thought I would post this question before buying. Thanks much!
Brokenwrench
09-22-2002 12:03:38
 Re: Are T6 oil filters the same as the TD6? in reply to Askel, 09-19-2002 15:07:26
The oil filter should be the same as a Farmall M or W-6 of the same vintage, all 3 used the same engine.
Jeff
09-20-2002 20:04:26
They changed the size of the filter over the years. There was a small diameter canister (about 3-1/2" or 4" in dia.) and a larger one (about 5" or 6" dia). My 1948 T-6 has the small one. I got a filter from Valley Friction in Chatsworth, Ca. Their phone number is (818) 407-1146 and the filter is a Wix brand part number 51125.
Jeff
JerePa
09-20-2002 18:05:34
They are different. You have to look in a industrial filter cat. not car & truck.
