JD 420C need info
Acid Ant
09-24-2002 16:42:42
I just bought a 420C, long story short I was screwed over. Engine apart now but bore size is not correct for 420. # on engine is T109669T any one know what it is from? Need to get many parts for rebuild any help would be appreciated. What other engines would fit and where to find?
Thanks
Acid Ant
09-27-2002 19:36:11
 Re: JD 420C need info in reply to Acid Ant, 09-24-2002 16:42:42
Where can I find the tag with Serial# ? I haven't been able to locate one except for on my loader? How else can I know for sure what I do have?
thanks
TonyK
09-28-2002 19:19:16
 Re: Re: JD 420C need info in reply to Acid Ant, 09-27-2002 19:36:11
Mr. Ant;
The serial No. name plate is located on the left side of the shaft/ clutch housing. It is held on by 2 blind rivits. However the serial No. is also stamped on a flat just behind the Hydralic pump and can be seen from the right side of the engine. Also it is stamped on the top of the transmission housing on the left side on a machined flat as well. There may be many layers of paint hiding it so you may have to scrape or use a bit of sand paper to read it. If orginal all the numbers will match.
TonyK.
clark
09-25-2002 08:13:54
i would sudjest you take the engine block to a good engine machineshop, they can measure the bore and give tell you if there is pistons that will fit the bore, also they can sleve the cylinders back to the standard bore if they are worne too much.. its alot cheaper to go this route than try and get another engine and possibly have the same problem/
Acid Ant
09-25-2002 07:51:18
 Re: Re: JD 420C need info in reply to CRAWLER HEAVEN, 09-24-2002 19:04:06
The bore measures 4.044 and the piston slops around in it with .095 to .100 clearance which I know is wrong. What engine is this? What is the max I can bore it out? The walls look to be a little on the thin side right now and it isn't sleeved.
Thanks
Lavoy
09-26-2002 10:02:09
 Re: Re: Re: JD 420C need info in reply to Acid Ant, 09-25-2002 07:51:18
Sounds like a the replacement M,40,320, and 330 block. Does it have a dipstick/filler on the right hand side of the block?
I can get pistons up to .125 over. I have had a block sonic checked for wall thickness, and my engine shop does not recommend .125 over for a machine that is to be worked hard on a regular basis.
Otherwise, bore it and sleeve it back to standard. I would recommend getting a 420 engine and putting back in it. You will like the additional horsepower.
Lavoy
Acid Ant
09-26-2002 13:01:03
 Re: Re: Re: Re: JD 420C need info in reply to Lavoy, 09-26-2002 10:02:09
Yes it does have the dipstick/filler on the right hand side of the block. Any other larger engines fit it?
Jim in michigan
09-24-2002 18:07:00
could be a 430 engine,.,,,Jim
TonyK
09-25-2002 13:54:13
 Re: Re: JD 420C need info in reply to Jim in michigan, 09-24-2002 18:07:00
Max size on this engine is 4.125" Deere does not have this size. .045 is max from Deere. Restoration Supply will sell you pistons that are .125" over as well as .090" over. Main bearing are available too. But... the wait is weeks depending on the size required.
I know what you are talking about. My engine was seized, the crank cracked bearings shot. I also had to put hardened seats on the exhaust values, nothing left to machine.
Any other questions, email me.
TonyK.
