850 c stopped pulling
david
09-24-2002 18:28:38
my 850 c stopped pulling today and I found a puddle of oil under the rear below the trans. Is this like a cat that if it gets the smallest leak in the suction line it will loose prime and not do anything? Of course its in the mud up to the belly pan,which has to come off to get to the lines etc...Full of oil still but the trans.pressure gauge shows 0 .Doesnt smell burned or dark in color. Whats the best way to start the search for the problem? Thanks, David
gatractorman
09-25-2002 02:00:13
 Re: 850 c stopped pulling in reply to david, 09-24-2002 18:28:38
Your on the right track with the suction leak thats where I would start, doesn't sound like its in a real good place to be dropping the pans and in my Case experience my arm needs a couple more hinges in it to get to anything from the top, mabye if you got something else that will move it push it outta the mud hole.
