Case 580K
J gere
09-27-2002 10:51:00
I have a crack in the frame, which is also the hydraulic fluid reservoir, any advice on the best fix that will last appreciated
AJ
09-28-2002 11:57:34
 Re: Case 580K in reply to J gere, 09-27-2002 10:51:00
You can weld the crack as the frame is a fabricated structure, I have welded many and had no trouble after, You will have to drain the oil and leave the cap off, if you can get at the crack with a small grinder vee it out a bit or at least get rid of the paint, start before the crack and finsh after it with the run of weld, try to get it with the one run, I use a low hydrogen welding rod, 7018 is the spec here in the UK. Have a bucket of water handy in case of fire and don't forget to disconnect the earth lead from the battery to protect the alternator
Good Luck
AJ
