Changing from a generator to an alternator
Case 450 loader
Mike D.
09-30-2002 15:24:05
Need some pointers-
The generator on our crawler is shot. I would like to change it out with a aternator.
Can I find one that fits the existing mountings?
Is there a specific type I should buy? Any tips about it would sure come in handy. Mike
Gary McKenzie
10-02-2002 05:43:45
 Re: Changing from a generator to an alternator - Case 450 loader in reply to Mike D., 09-30-2002 15:24:05
There are several good articles on this subject on this site. Look under Articles (Research & Info). One wire conversions work okay, but if you want to keep the warning light operative you'll need to do it a little differently. Some of the articles have schematics and can guide you step-by-step. Hope this helps!
Rob J
10-02-2002 07:08:03
 Re: Re: Changing from a generator to an alternator - Case 450 loader in reply to Gary McKenzie, 10-02-2002 05:43:45
On the 2 wire Bosch's I mentioned, one post is the output and the other is the hot or exciter (?) wire. This is the post that went to the light if I recall. We installed a diode to keep the 12v going TO the alternator and not back to the switch. The diode also kept some of our fail safe devices (low oil pressure and high temp kill switches) from getting juice back from the alternator.
Ahhh the good ole days.
Gary
10-02-2002 00:56:46
Mike
Ihave put 3 of these on diffrent things Dozer,tractor and car they work great. On 2 of these they had + ground I had to change them to - ground witch is no big deal.
good luck
Gary
Bill
10-01-2002 15:27:04
I have done the one wire alternater conversion MANY times. Highly recommend it. My only other observation others failed to mention is where to get it. Personally I get a kit from JC Whitney & convert either a used one or get a new one from Autozone for $20 if you don't want the lifetime warrantee. You can use late 70's -early 80's GM alternater. I ask for a 79 Caprice with air cond. at Autozone & that gets you a 50 amp Alt.You'd lose the warrantee soon as you made the conversion/why pay for it? JC Whitney also sells them ready to bolt on .... Enjoy....
Russell
11-04-2002 23:57:29
 Re: Re: Changing from a generator to an alternator - Case 450 loader in reply to Bill, 10-01-2002 15:27:04
Can you give me more info on how you hook up one wire and why/where do you need a generator? Excuse my ignorence. Ì'm working on a new form of power suppy.
Bill
11-05-2002 14:43:16
 Re: Re: Re: Changing from a generator to an alternator - Case 450 loader in reply to Russell, 11-04-2002 23:57:29
It's kinda simple. You take off the generator, throw it away or put it on the shelf. You mount the one wire alternator in the generators place ( belt drive ) Run the one wire from the alternator right to the battery positive side ( #10 wire ) through an amp gauge if you like, start the machine up & your charging...
D. Andrews
10-02-2002 04:48:02
I use an A-zone alt on my tractor, gen conv. and they honner the lifetime warrenty on it, I get one for an 81 chevy 3/4ton truck, w/o air, works like a charm, and I usually replace it once every two years, tractor is out side, no cover..... D....
Rob J
10-01-2002 06:24:10
I've never heard of a one wire but it sure sounds simple. I still have about 6 of some old bosch alternators I pulled off of diesel engines when I was a mechanic. We use to throw these things away because we couldn't use them in the oil fields. Everything had to use an air starter.
Anyway my comment is you can save your money by getting a smaller alternator. A 20-30 amp is all you need to just charge a battery. These little bosch's were 33a.
Rob
marlowe
09-30-2002 18:31:49
go with a delco one wire that is a easy switch the only thing you got to do is make a new mounting bracket witch is no big deal
david
09-30-2002 18:29:51
get a one wire alternator so you dont have to mess with wiring up a voltage regulator.They are by far the simplist setup and are considerable cheaper.Just attach the hot wire to the alternator and then through the amp gauge and then to the battery. Good luck,David
