AC HD7W Master Clutch hard to use
Andy
10-02-2002 14:59:56
Having trouble when I pull back on the master clutch lever to move the tractor.It's very hard to get over center and lock all the way back.After awhile, it gets so the gears will hardly engage then once I grind the gears a bit,the clutch is much easier.Manual says something about a locking ring to adjust but can't find it.also says soak clutch with oil but that just goes against the grain.Thanks for help.
Andy in Georgia.
ACPhil
10-05-2002 19:49:25
 Re: AC HD7W Master Clutch hard to use in reply to Andy, 10-02-2002 14:59:56
Andy, I just got hold of a HD 7 service manual. If you want, I can make you copies of the pages that have to do with the clutch. Use my Email address and drop you your mailing address, if this would help you. Phil
