843 Bobcat hydraulic pump
Pat Evans
10-07-2002 07:31:16
Does anyone know where I can purchase a hydraulic pump or parts for the pump that raises and lowers the bucket on an 843 bobcat skidsteer? The bushings are worn inside and it could also use a couple of gears and shafts. I know I can get one at a bobcat dealer but they are very expensive.
gatractorman
10-08-2002 02:21:45
 Re: 843 Bobcat hydraulic pump in reply to Pat Evans, 10-07-2002 07:31:16
Your on the right track dont give Bobcat's price for a pump, try this number as well 1-800-238-0375 thats for Flint Hydraulics in Memphis, TN.
Pat Evans
10-08-2002 04:51:11
 Re: Re: 843 Bobcat hydraulic pump in reply to gatractorman, 10-08-2002 02:21:45
Hey Thanks for that info. Bobcat wants around $800. for it. The part number I need is 25386RAM. I will definately try the Memphis number.
Bob /Ont.
10-07-2002 08:11:36
Pat, if the bushings are worn that bad the gears will have cut the housing out so you best go for a whole pump, likely cheaper than parts. If you can find the maker's name on it any where call some local hyd shops. GaTractorman will likely be allong soon and he will know where you can get the best deal if you don't find anything.
Later Bob
Pat Evans
10-07-2002 18:15:19
 Re: Re: 843 Bobcat hydraulic pump in reply to Bob /Ont., 10-07-2002 08:11:36
Thanks for the input Bob. I have since found that it is a Cessna pump. I will find out the part number tomorrow. The local shop can get me one for about $425.00 american. It must come from the west coast. If anyone knows of a better deal I would appreciate knowing about it. I will post the part number when I can. Pat Evans
