Hey Bernie,,430C picture
Jim in Michigan
10-08-2002 06:32:56
third party image
bernie here is a pic of my 430C hood is off,but I have all the sheet metal..thinking about painting it up next year,,,Jim
Bernie
10-11-2002 09:38:02
 Re: Hey Bernie,,430C picture in reply to Jim in Michigan, 10-08-2002 06:32:56
I couldn't make your picture come up. I just bought another 420 with a 62 blade with twin cylinders. My original one has a 61 (farm blade) that works with a remote cylinder. You pin the blade up and use the cyl on whatever you're pulling behind, harrow,etc.
This "new" 420's engine is stuck and I've been trying different ways to get it loose. I rigged up a tank over a gas burner piped to the block to circulate boiling water, but hasn't worked so far. Kroil won't even go down (the head is off). I drilled a piece of square tube to line up with the head bolt holes and tightened a block down on #1 piston; no luck. I'm going to try #2 and then I guess it will be pull the belly pan and oil pan. I also loosened the starter in case it was stuck. Anybody have other ideas? Thanks.
Jim in Michigan
10-11-2002 10:39:43
 Re: Re: Hey Bernie,,430C picture in reply to Bernie, 10-11-2002 09:38:02
bernie,, I used a block of wood that fit in the cylinder and hammered it,,worked great and didnt even hurt the rings,,, email me if you get a chance,,would like to hear more about your crawler,,,Jim
Lavoy
10-08-2002 12:57:59
Jim,
Do you mean 420C?
Lavoy
Jim in Michigan
10-08-2002 15:06:03
 Re: Re: Hey Bernie,,430C picture in reply to Lavoy, 10-08-2002 12:57:59
Lavoy,,mine is a 430C not a 420C ....Jim
Jim in Michigan
10-08-2002 19:19:15
 Re: Re: Re: Re: Hey Bernie,,430C picture in reply to CRAWLER HEAVEN, 10-08-2002 16:58:37
Well,,we bought it from the second owner, they stated it is a 430, possibly I am wrong,,the numbers plate is gone,,,,Jim
Lavoy
10-09-2002 09:35:13
 Re: Re: Re: Re: Re: Hey Bernie,,430C picture in reply to Jim in Michigan, 10-08-2002 19:19:15
Jin,
By looking at the shift lever and the steering levers, you have a 420 under about 111,000 serial number. Look at your track clutch housings, if they have two bolts per side bolting them to the side frames, then you have a phase one 420 with a serial number under 100,000. Another way to tell is under 100,000 the serial number is on the left side of the center frame, 100,001 and up it is on the left side of the bellhousing. Go to my website and you can see pictures of both 420 and 430. I think you will see immediately the difference.
Lavoy
Jim in Michigan
10-09-2002 12:29:13
 Re: Re: Re: Re: Re: Re: Hey Bernie,,430C picture in reply to Lavoy, 10-09-2002 09:35:13
Lavoy,,your 420 Pictures show a top roller for the tracks,, ,,mine has 5 lower rollers but no uppers,,also do you have parts? I need the handle assembly that controls the hyd for the blade,mainly I need the lil tab and spring,looks like the one on the 430 project,also the "next page" function on your web page doesnt work,Jim
Lavoy
10-10-2002 12:00:22
 Re: Re: Re: Re: Re: Re: Re: Hey Bernie,,430C picture in reply to Jim in Michigan, 10-09-2002 12:29:13
Jim,
I can only see 4 rollers on your 420 unless I am missing something. Four roller crawlers did not have a top idler. I am out of hydraulic levers right now.
Tried the second page just a bit ago and it went, you may want to try it again.
Lavoy
