7JD4 Clutch
Warren Deglow
10-12-2002 18:44:38
Does anyone know how to adjust the clutch on a 7JD4? I used to own a 5JD2 but it is not the same.
TomA
10-14-2002 09:29:13
 Re: 7JD4 Clutch in reply to Warren Deglow, 10-12-2002 18:44:38
There is a 1/2" bolt that takes a 3/4" socket that clamps the collar on the mainshaft. You have to turn the shaft to just the right position to get at it. A universal socket is helpfull. Once it is loose, put the transmission in gear and clutch released, rotate the collar clockwise (from rear) until the clutch will snap over center with moderate pull. Tighten that clamp real good. It is similar to D2, but a bit more hassle.
