JD 450 C dozer front idler adjustment
Novice, but lea
10-14-2002 08:48:31
Operator status: Novice: Recently purchased a JD 450 C dozer and the front idlers appear to be out of alignment. Both seem to be wearing on the left side of the chain. The manual shows the use of shims to adjust the yoke, however, a mechanic (works on JD and other heavy equipment) said that it is normal to have the idlers float from side to side and to put in more shims on one side versus the other would put the bolts and yoke out of square. Any comments?
Novice, but learning (NBL)
