HD-5
Larence Blevins
10-15-2002 20:33:58
I am working on a 2-71 detroit and need to know what to set the valve and injector clearance at.
If someone can tell me I would be most grateful. Thanks Larence
Chuck Hilton
10-17-2002 18:24:02
 Re: HD-5 in reply to Larence Blevins, 10-15-2002 20:33:58
Larence, The injector timing dimention will can be different depending on the injector number (HV6is common for these) Let me know the injector number and I will get the specs for you. There is a gauge for setting the injectors but you can have good success with an accurate dial caliper. Chuck
John - NY
10-16-2002 07:32:07
When I set the valve and injector clearances on my HD 15's 671 Detroit Diesel, a mechanic at a truck repair shop showed me on an engine they had in the shop and let me borrow a guage to set it. They did the repair work on my cylinder head and were invaluable as a resource. This was years ago and I have never forgot their kindness. I still do business with them.
Maybe you can approach a local truck or tractor repair shop for advice.
With some advice and that guage you should be able to set it accurately.
Best of Luck!
John
