I bought the 500C
questions
Tim
10-21-2002 20:54:12
third party image
I posted a few days ago about the crawler loader I looked at. I have the serial number but am not quite sure of the breakdown of it;
4070006C003471*
I think the 4070 means it is a '74 although the seller said it was a '75. I have no idea what the * is for but I have some questions I hope I can get answered. The machine is plated as from a Hamilton Canada dealer and was in Washington State for the past 15 years.
It has a Drott 4 in 1 bucket model # 57198, ser # 742. The engine is cast with 3055000R3 on the side. Besides having to adjust the track and brakes, along with tightening some hoses and connections things looked pretty good. I smell a bit of brake or clutch when working it hard and it uses some oil. I got the service manual for the engine as well as the chassis but no owners manual explaining the particulars.
I am looking for the following items;
owners manual
amp guage
battery compartment cover
oil temp sending unit
tranny temp sending unit
tune up parts (belts filters)
anything I can find would be great I'm going to post some photos at my website
Link
Lee
05-05-2003 12:58:07
 Re: I bought the 500C - questions in reply to Tim, 10-21-2002 20:54:12
Manuals: Got mine from Dresser before Komatsu bought Dresser. I would be hard pressed to say the manuals were worth the money they charged, as they were photocopied photocopies of blurry microfiches - the text in some manuals was so blurred as to be nearly useless. But then again, something is better than nothing, considering the age.
Tim - Looks like you only have a portion of the maximum rear weight complement; I got 6 more leaves of weights with my rig. My 500C came with 3142A backhoe, when the hoe is mounted, the 500C really needs the front of the machine to be counterweighted, I put the weights in the bucket when the hoe is mounted. My machine is about the same age, and is also 3 cylinder diesel, yours is obviously diesel as well. If you could, please post your transmission temperature, I think I'm running mine at ~230-250 Farenheit operating temp. Or maybe (I hope) the temp sensor is really wrong.
Steering Clutches.... IIRC, a company named Rockford made my steering clutches; whatever the name, they still made clutches as of 2 years ago.
Maybe somebody could email them about parts availability - I dropped an adjuster a couple years ago when grading and it tore out a single spring on the pressure plate. Now that side is a tad weaker and slips, so I'd like to get the spring and cup, or possibly an overhaul kit.
Tip: my machine has the 2 stage hydraulic pump for the hoe attachment. The inlet (suction) line would leak about 15 gallons per winter, no matter how much I reefed on the tubes nut. I used a Loctite sealant on the flange and now I lose only about 3/4 gallon per year including winter. If I forget to come back, feel free to modify the email address to remove .org.edu and send me a message.
Rick from Paso
10-23-2002 20:26:04
Congratulations on your new baby! How much did you pay for it? I bought mine last January and love it. I need to replace my steering brakes and rebuild the hydraulic valves. I paid 4K. Good luck with it, I posted a pic on the tractor pics, search for 500C, post a pic of yours too!
Bob /Ont.
10-25-2002 19:56:41
 Re: Re: I bought the 500C - questions in reply to Rick from Paso, 10-23-2002 20:26:04
Rick, you got your's pushing good now?
Later Bob
Tim
10-24-2002 08:12:36
great !
I made a website with several pics,
Link
Tim
jim
10-22-2002 19:28:32
Call your local Komatsu dealer for the parts on the machine as they have purchased Dresser which had bought out the IH construction line - they should be able to get you the manuals and most parts. If it has the gas engine get the part numbers from the Komatsu dealer and call the ag dealer with the part numbers as they usually are cheaper because was more common in the tractors.
Stacy
12-28-2002 12:27:00
 Re: Re: I bought the 500C - questions in reply to Milton, 10-22-2002 08:35:43
I am looking for a service manual for a500c dozer, any ideas where to look?
DSchmidt
11-30-2003 22:58:43
 Re: Re: Re: I bought the 500C - questions in reply to Stacy, 12-28-2002 12:27:00
I just bought a 500 series e loader and received a 500 series c dozer service manual. Are you still looking?
