580 Case backhoe
Doug
10-25-2002 04:29:31
Can anyone tell me the weight of a case 580 backhoe loader and also the weight of an older 450 case dozer's weight and HP. Thanks Doug
Max
10-25-2002 15:19:22
 Re: 580 Case backhoe in reply to Doug, 10-25-2002 04:29:31
About 13,500 lbs and the 450 is 50hp for the dozer and 52 for the loader version. The weights of the 580 and 450 were close to the same weight.
Doug
10-25-2002 12:24:08
580 Case is a CK 2 wheel drive with a 4cyll., Diesel
Charley
10-26-2002 06:29:19
 Re: Re: 580 Case backhoe in reply to Doug, 10-25-2002 12:24:08
I have a 580 CK loader backhoe and the owners manual lists it's weight at just under 10,000. It's gas, so a diesel will be a few pounds heavier.
Doug
10-26-2002 15:05:49
 Re: Re: Re: 580 Case backhoe in reply to Charley, 10-26-2002 06:29:19
Thinks for the info Folks, But I bought a 40 MF That didn't Need Much Work ( The Ck Needed a rear axle housing )
M.R.
10-25-2002 10:25:53
A 580K phase 3, 4x4, ext. hoe, with 4 in 1 will weigh just shy of 18K.
Horsepower
10-25-2002 05:44:17
I have a Case 580C with extendahoe and loader bucket. As I remember weight is about 13,500 lbs.
