HD5 Allis
John Kinsey
10-25-2002 06:00:46
A friend has an HD5 that has a broken right rear axle. Does anyone know if an axle from a HD6 is the same?
Thank You
John
ACPhil
10-26-2002 17:30:09
 Re: HD5 Allis in reply to John Kinsey, 10-25-2002 06:00:46
Hello, Yes the Sprocket shaft from a HD 6 will fit the HD 5. The early HD 5's had six splines where the sprocket goes on. The later model 5's and all 6's have 10 splines where the sprocket goes on. I'm not exactely sure about the number of splines, but do you get the picture? If the sprocket is good from the HD 6 machine just use that sprocket with its sprocket shaft. It's a plenty big job to change the sprocket shaft. Colorful words always help. Let me know if you need any more info. Phil
John Kinsey
10-27-2002 06:40:17
 Re: Re: HD5 Allis in reply to ACPhil, 10-26-2002 17:30:09
Phil,
Thanks for your response. My friend has a HD6 rear end with good axles but I'm not sure about the sprocket. We will have to check to see if they both have the same number of splines.
Thanks again
John
Weekend Farmer
10-28-2002 14:15:41
 Re: Re: Re: HD5 Allis in reply to John Kinsey, 10-27-2002 06:40:17
Hi, I've been looking for a right steering clutch & break band for my HD5. Do you have any to spare from the parts dozer?
Thanks
Weekend
