Dozer Blade Question
Ron_NY
10-28-2002 05:29:59
Almost all of the dozer blades I have seen are relatively short (mabe 24 - 36 inches tall) and straight. I recently saw a blade mounted on a Cat dozer that looked very different. The blade is a total of 10 feed wide, with the ends angled in maybe 15 - 30 degrees (I didn't measure). These angled ends were 18" long, the length of the cutting edge. In addition, the blade was over 4 feet tall, with the top section wire mesh in a heavy frame.
Any comments on the angled vs straight blade would be appreciated. I assume that the height of the blade was intended to protect the engine compartment from brush. Is this thinking correct?
Thanks for your help.
Ron in Central New York
Steve NY
10-28-2002 05:46:53
 Re: Dozer Blade Question in reply to Ron_NY, 10-28-2002 05:29:59
Ron: You are somewhat correct. Most machines with those types of blades (semi-U and U blades)were designed mainly for realitivly light work. Many were used in landfills where the material being moved was light in weight. This not to say that they are no good for dirt work by any means. It's just that machines that were headed for landfills and the like were fitted with larger blades to move a larger volume of material in one pass. "A blade full". With dirtwork the same machine probably would not be able to handle "A blade full". The U shape is to facilitate the "carrying" of material long distances, so as not to lose half of the material. The wide blades are great for finish work. The very tall height of such a blade will make it a bit difficult to see what your doing. It would take some getting used to thats all.
www.pdmechanical.com
