D7 clutch
mark
11-14-2002 14:08:01
Broke a cam in the clutch on the d7-put a new one in.Clutch doesn't release,doesn't feel right when you engage and disengage.Do i need to adjust the hand clutch or something else
hector gemme
02-10-2005 14:17:28
 Re: d7 clutch in reply to mark, 11-14-2002 14:08:01
HI I HAVE SOME USE D7 PARTS
Kelly
11-14-2002 15:42:22
Mark,
I would suggest that you reajust the master clutch. Did you replace all the clutch cams?, if not the new one my be taking the full load of the clutch pressure. I would suggest that you install a full set of clutch cams, if you did not do so. Also, I would look the machine over to determine what caused the breakage of the cam in the first place if, it was not wore completely out, loose motor mounts, and etc.
Bob/Ont
11-14-2002 15:06:16
Mark, I assume you mean the flywheel clutch. If you put in a new one and the others are worn this might be your problem. However, yes if you do change anything then you should adjust it to get the correct over center pull. If the clutch seems to drag when you adjust it for pull and have it released then, change the other cams too so they will all be the same.
Later Bob
