A. P. ANDERSON INC CRAWLER MDL F3A
DAVE PHILLIPS
03-11-2001 11:32:58
THE CRAWLER HAS A OLIVER ENGINE. NEED ANY INFO RE: YEAR, PARTS AVAILABILITY FOR ENTIRE CRAWLER AND ANY OTHER INFO ABOUT THE MACHINE
Gary Hearn
03-11-2001 17:28:32
 Re: A. P. ANDERSON INC CRAWLER MDL F3A in reply to DAVE PHILLIPS, 03-11-2001 11:32:58
What you have is an A. C. Anderson blade mounted on an Oliver crawler. If it truly has an Oliver engine, then it would be an OC-6. However, I would guess that it is a smaller crawler (i.e. HG, OC-3 or OC-4) with a Hercules engine and Oliver stamped on the manifold.
Can you provide a better description of the tractor (size, weight, # of cylinders, etc.) or a picture so we can better help you? Look for a serial number plate on the left frame rail below the clutch, on the bellhousing or if an OC-4, next to the hour meter.
dave phillips
03-14-2001 16:54:11
 Re: Re: A. P. ANDERSON INC CRAWLER MDL F3A in reply to Gary Hearn, 03-11-2001 17:28:32
to gary and others
the crawler has a label plate with the following info: model no. oc3-42-ind, and serial no. 13wh-440.
what is the year of the tractor, weight and any other info that may be derived from the model and serial nos above. is there a source for parts and manual for the above model crawler.
thanks for response and any info that may be available
