IH500c Transmission leak when cold
Kurt
11-26-2002 15:29:34
Hi, When I start to use the machine when it's cold (below 30 degrees), it leaks about a pint or a little more transmission fluid until it's been driven for about 15 minutes or so.After that it won't leak a bit and everything works fine. Is this a problem to worry about or just keep the fluid up? Thanks for any help!
Tom Spivak
11-27-2002 14:48:16
 Re: IH500c Transmission leak when cold in reply to Kurt, 11-26-2002 15:29:34
If you have the proper fluid in it then it sounds like the seals may have gone hard. I have experienced the same problem on other machines I have owned and have had good success with putting a pint of brake fluid in and running it as you normally would. The brake fluid seems to soften up the seal and make it seal better. I had one machine that lost two quarts in 45 minutes and I put the brake fluid in and it sealed to a stop after a couple days, didn't leak again for the next 4 years I owned the machine.
Chris
12-04-2002 03:59:29
 Re: Re: IH500c Transmission leak when cold in reply to Tom Spivak, 11-27-2002 14:48:16
I agree with the comments from tom, I just changed the torque converter seal in my 500C Dozer, also was told a while ago about the brake fluid trick from a tranny guy IT WORKS!
Good luck
