420 Steering Clutches
Keith Harris
12-05-2002 20:49:07
I am in the process of renewing the right steering clutch. Can anyone explain why the fibers I have removed are thicker than the currently available fiibers. I have at least one fiber that mikes at.184. The rplacemnets are approx .151. The throwout bearing is definitley up against the pressure plate, eeping the clutch in a constant state of release. The old fibers still have lots of wear in them and I would like to reuse them if possibility. Or, does any one have a source for the "fatter" fibers. Thanks for
Richard in W V.
12-11-2002 05:56:55
 Re: 420 Steering Clutches in reply to Keith Harris, 12-05-2002 20:49:07
keith the compositing facing is.183-.193 for those model using six plates or .145- .151 for models using seven the steel plates are .090-.093 for all models hope thgis well help.
Paul
12-06-2002 03:06:17
Ihad the same problem in my 440 the release bearing carrier was not going back there is 3 and maybe 4 balls behind the carrier and if it has been out of adjustment it get's pulled to far then won't go back check it.
