4500 Ford Backhoe problems
Richard Alaniz
12-11-2002 10:44:11
I have a 70's model backhoe that takes on an engine strain when the main boom is raised. It operates ok but it seems that the pump may be weak,when the heavy digging comes in the pump seems to bring the engine rpm low, how do I find what the problem is? where can i get a replacment pump? thanks Richard
Bob /Ont.
12-11-2002 13:21:06
 Re: 4500 Ford Backhoe problems in reply to Richard Alaniz, 12-11-2002 10:44:11
Richard,I don't think you have a pump problem, it sounds to me like an engine problem. What type of pump does the machine have on it?
Later Bob
Ed/Ohio
12-11-2002 15:38:21
 Re: Re: 4500 Ford Backhoe problems in reply to Bob /Ont., 12-11-2002 13:21:06
Richard,.. Does your hoe have a safety lever to the right of the hoe controls ? It will be a small curved metal lever with a black ball on the end. It is a safety that will not allow the main boom to raise or lower. Try moving that lever up. It might free up you boom and take that strain off of the engine. Just a thought ?
See ya,..... .out.
Flee
Buddy
12-12-2002 14:16:47
 Re: Re: Re: 4500 Ford Backhoe problems in reply to Ed/Ohio, 12-11-2002 15:38:21
I would check all the filters,fuel, air,and the inner air filter. I have seen hyd filters in Ford backhoes collapse and suck together. Check for a pinched hose and a kink in the steel lines where they run under the machine.
