Ford backhoe boom pin
moe
12-11-2002 18:34:31
i have an 86 555 a and the bottom back boom pin fell out. the bracket with the bolt is still there. can i just get a solid 2" piese of steel and weld the bracket back on or do i have to fork out the 120.00 bones the dealer wants????? any input is welcome...
Dave
12-11-2002 20:44:36
 Re: ford backhoe boom pin in reply to moe, 12-11-2002 18:34:31
You don't have to get the pin from Ford but my experience has been if you procure a comparable (one that will do the job) pin which is good steel and heat treated it will cost you as much as, or more than, the Ford pin - unless you have an 'in' somewhere. Many years ago I tried a non heat treated one in my boom, was a pisser to get it out (it bent quickly). The right pins and bushings are expensive, I just put a thousand dollars worth in my 750. Hard to beat the system!
Bob /Ont.
12-11-2002 19:16:38
Moe, that pin needs to be made from good material not just mild steel. A soft pin will bend and you will not be able to get it out again.
Later Bob
