Hard Starting 4500 ford backhoe
Richard Alaniz
12-16-2002 07:01:14
I have a mid 70s 3cyd diesel backhoe that does not like to start.It does not smoke or show signs of engine wear,but cold or hot it does not like to start.It takes a shot of starting fluid to get ger going. Also seems to take a bit long to rev up to high rpms. When I put a hydralic load on the engine it brings rpms down, Hydralic pump or Injection pump, Anybody have one of these things Thanks..Richard
RAB
12-19-2002 14:09:28
 Re: Hard Starting 4500 ford backhoe in reply to Richard Alaniz, 12-16-2002 07:01:14
You probably have, but I'll ask anyhow. Have you checked that the stop control is going, and staying, completely home? (eg is wire long enough) Can cause your symptoms.
Regards, RAB
Bob /Ont.
12-16-2002 07:39:47
Change the fuel filters and clean any screens in the fuel system first. Then see about a fuel pump overhaul. Sounds like low fuel delivery if it's hard to start and not smoking. Bad nozzels will give you smoke and so will a worn out engine.
Later Bob
Richard Alaniz
12-16-2002 08:26:49
 Re: Re: Hard Starting 4500 ford backhoe in reply to Bob /Ont., 12-16-2002 07:39:47
I have replaced the fuel filter and the fuel pump
Bob /Ont.
12-16-2002 08:33:33
 Re: Re: Re: Hard Starting 4500 ford backhoe in reply to Richard Alaniz, 12-16-2002 08:26:49
Richard, the pump you replaced was the lift pump that moves the fuel from the tank to the fuel injection pump, right.
Later Bob
richard alaniz
12-16-2002 12:16:41
 Re: Re: Re: Re: Hard Starting 4500 ford backhoe in reply to Bob /Ont., 12-16-2002 08:33:33
Yes it was the transfer pump not injection
Bob/Ont
12-16-2002 12:27:33
 Re: Re: Re: Re: Re: Hard Starting 4500 ford backhoe in reply to richard alaniz, 12-16-2002 12:16:41
Well Richard if you are sure the fuel supply line has nothing clogging it, as you likely are then you could safley get someone to look at the injector pump. If it's a rotary pump they have a small vane pump inside them too that charges them, hope for the best.
Later Bob
