'65 Case310G crawler....help!
Tracy
12-19-2002 11:41:59
This is (was) my father's tractor and now I have to deal with it so bear with me.....when you let the clutch out in gear the tractor sits and 10 sec. later it takes off. It seems to slightly help it if I move some hydrolic lever..... .is the clutch bad and needs replacing? Or is it hydrolic related? It is a 4 speed gas model and in the service manual section 5 is titled "torque converter" but the only insert is titled "10"traction (dry)clutch and drive shaft." Thanks in advance, Tracy
Tracy
12-22-2002 11:17:36
 Re: Re: '65 Case310G crawler....help! in reply to CRAWLER HEAVEN, 12-19-2002 13:42:18
Thanks for the advice.....and sorry I haven't answered back sooner, our power just returned....80mi/hr winds here in Big Sur, CA.
Your'e right it's a 3 speed.There are a couple of parts I need to get it going again but I will do as you advise. If the drive shaft is turning that means the clutch is OK but the diff. is failing?
Thanks again for the help, Tracy
