Cat D333 engine
tom
12-26-2002 03:52:23
i have a clean D333 diesel , had an new turbo installed and had very little use. My question, what equipment was that engine used in. I have no use for it now and wound like to sell it.
Kelly
12-26-2002 22:49:39
 Re: Cat D333 engine in reply to tom, 12-26-2002 03:52:23
Tom, the D333 engine, was used in industrial Power Units
Electric Sets, and Marine use.
They were also used in the D5,D6B,D6C,627,816,814,966C,977H,977L,
No.12E,No.12F,No.14C,No.14D,and No.14E
Bob/Ont
12-26-2002 04:13:03
977/966/D6/ Genset, Industrial power. It will need to have attachments swaped over from the engine it is replacing and the governor setup for it too.
Later Bob
gatractorman
12-27-2002 02:06:47
 Re: Re: Cat D333 engine in reply to Bob/Ont, 12-26-2002 04:13:03
Hey Bob, what engine was used in the 941 loaders? I thought it was the 333 and a turbo-charged version in the 955, I've got a 3304 out of a 951c, guy was running it without a bellypan and you know what happened, I thought mabye it was repairable till I took what was left of the oil pan off and found the oil pump had took a shot and broke the block around the balance shaft bearing.
Bob /Ont.
12-27-2002 07:21:42
 Re: Re: Re: Cat D333 engine in reply to gatractorman, 12-27-2002 02:06:47
You'r streatching my memory here Tractorman but I think D330 is the 4cyl 4.5" bore D330C a 4.75 bore. The C models where much like a 3300 series but not exactly the same. If you are doing this job Email me and maybe we can figure out if something you find will work in there.
Later Bob
gatractorman
12-27-2002 02:13:17
Oh, I forgot to add this guy knew when he done it but decided to try to run it back to the house so it would be close to work on it, made it about half-way and locked up, and BTW this guy is an airline pilot wouldn't you like to fly with him?
Bob/Ont
12-27-2002 07:11:09
 Re: Re: Re: Re: Cat D333 engine in reply to gatractorman, 12-27-2002 02:13:17
Hi Tractorman, he would have been okay if the loader had a bit more altitude, he would have been able to glide home okay:<) Tell him that, "too little altitude" is the catchall blame phrase for air accidents.
Later Bob
