Cumberland FFA's TD9
Preston
01-05-2003 19:06:59
I posted a message at the end of December about not being able to find the serial number on our TD9 dozer. On Jan. 4, we found numbers on the block but they are not serial numbers. If someone knows a way to use these numbers to find the serial number or history information, please e-mail me. The numbers we found are 8124-DK, and 6 29 R. Both of these numbers were found on the right side under number 1 cylinder, behind the diesel pump. All the help is greatly appretiated. Thanks.
TD-9
01-06-2003 08:28:11
 Re: Cumberland FFA's TD9 in reply to Preston, 01-05-2003 19:06:59
the tractor serial number should be on the side of dash (operaters side).should be something like TDCB_____ ___, engine serial is stamped on left side of crankcase (above injection pump I think) TDCBM_____ _____. these numbers will help determine series and age. other factors to determine age and series, location of air cleaner between legs or under hood,location of shifter bettween legs or off to side, gas over diesel 4cyl or 282 6cyl or gas engine i got one of those. i can look up year if you get serial numbers.
