580D Slow hydraulics to backhoe
LAG
01-07-2003 11:52:14
My backhoe is digging slower than it use to.I replaced the hydraulic pump and it didn't help. The front loader is still good and quick and I replaced the fluid and the filter,So if anyone has an idea,I could use the help!!
MD SKY
01-09-2003 15:42:54
 Re: 580D Slow hydraulics to backhoe in reply to LAG, 01-07-2003 11:52:14
On Case tractors with detachable backhoes the
quick connects wear due to vibration. Restricting oil flow to the backhoe valve.There are two between the hoe and the tractor. Just a thought.
Max
01-08-2003 19:30:33
Did you check the steering priority valve with a pressure guage? Could be you are loosing flow that that part of the circuit. There was a service buletin put out in 82-83 on how to check it so maybe someone still has a copy. I beleive the test was to bring the crowd cylinder to releif which should be about 2400-2500 psi and then reach back with the other hand and hold the steering wheel in a far left or far right turn and the pressure guage should read 2600-2800 psi.
Max
01-08-2003 19:32:31
 Re: Re: 580D Slow hydraulics to backhoe in reply to Max, 01-08-2003 19:30:33
If the first pressure is off, repalce the oring on the power beyond fitting in the loader control valve. Sorry, that's the first place to check.
