Final Drive steering clutches
Jim
01-12-2003 09:41:32
My trow-out bearings slide on the bearing carrier loosly, is this correct or should they be pressed on? Any info will be appreciated.
Thanks, Jim in Oregon
gatractorman
01-13-2003 02:22:01
 Re: Final Drive steering clutches in reply to Jim, 01-12-2003 09:41:32
The actual throw out bearing should have to be pressed on to the carrier although it doesn't take much I usually pop them together in a bench vise, but the T.O. bearing and carrier assembly should slide freely on the pipe they ride on inside the housing.
Jonathan
01-12-2003 14:56:14
They should slide relatively easily...as thats how you want them to release the pressure plate ...
Lavoy
01-12-2003 09:49:08
What crawler are you working on, we need more info.
Lavoy
Jim
01-12-2003 13:56:29
 Re: Re: Final Drive steering clutches in reply to Lavoy, 01-12-2003 09:49:08
Oops!! The crawler I'm working on is a straight JD 350. The throw-out bearings slide on the bearing carrier loosely, is this correct or should they be pressed on?
Thanks for any info.
Jim in Oregon
